Author Topic: never fails  (Read 4606 times)
Offline racinrich
never fails
« on: June 17, 2013, 10:34:40 PM »
finished up my replacement of engine trans drivetrain,front wheel bearings engine harness fuel injectors cleaned ,new fuel lines tires,throttle cable,all things considered it went smooth, all fairings and johnny blanket in place ,I get 3 blocks from home and the only thing I didn't replace the clutch cable snaps.both ends looked fine no fraying. try going through a traffic circle with no control pucker factor
1993 k1100 lt silk blue
des plaines ill
USA
Re: never fails
« Reply #1 on: June 17, 2013, 10:38:03 PM »
greetings racinrich...
you gotts to finesse it...
turq
Re: never fails
« Reply #2 on: June 17, 2013, 10:46:11 PM »
Tell us more on the traffic circle handling. Ha!
After the cable; it'll ride for miles and miles and miles.
Offline racinrich
Re: never fails
« Reply #3 on: June 19, 2013, 08:58:29 PM »
was up in 4th got it down to 3rd but couldn't tickle it down to 2nd so I slowed luggin it and shot the first gap from the left hoping the flow from the rt wouldn't shoot out in front of me them same thing on the third feed in. I run this daily and usually hit it no fear but with this thing lugging i had to look for a way out if the stupids are behind the wheel,pull out in front of you them stop and give you the deer in the head lites look.don't scare easily but powerless out of control and along for the ride is NO fun !!!
des plaines ill
USA
Beemer01
Re: never fails
« Reply #4 on: June 20, 2013, 01:25:51 PM »
False Neutrals are occasionally a good thing.
