Author Topic: Fuel Range  (Read 9319 times)
Offline 2000rsv
  • Ride Far - Ride Fast
Fuel Range
« on: June 16, 2013, 11:12:20 PM »
'86 K75C.  Ride it fairly conservatively.  Filled with 87 octane, non-ethanol fuel (pure dino, baby  :2thumbup:).
The low fuel light came on at 130 miles.  Ran out of gas at 163 miles.  This range seems a bit short.  Put 5.1 gallons into the tank.
Is this normal?  (I know it's not, but what might be going on?).
BTW, I was running it out of gas as an experiment to see how far a tank would take me.  I had a full gallon gas can strapped on the Reynolds rack.
Re: Fuel Range
« Reply #1 on: June 17, 2013, 12:01:16 AM »
greetings 2000rsv...
if it were me i would be thinking about new air filter... new spark plugs... 2 bottles of techron in 4 tanks of gas... throttle body sync... and of course revving it on the redline more often than not...
Re: Fuel Range
« Reply #2 on: June 17, 2013, 12:08:25 AM »
what he said.  You should be getting 42, not 32 mpg, I get 48 at a steady 70mph.  Check the valve clearances too.
Offline Grim
Re: Fuel Range
« Reply #3 on: June 17, 2013, 08:46:43 AM »
Do you do a lot of short trips of under 5 miles?  Do you have the factory rated thermostat?
When a fuel injected engine does not reach full operating temp it runs a rich fuel map through warm up. So short trips or a lower then specified thermostat will cause it to use extra fuel.
My 95 k1100 gets 45mpg in the mountains on long runs but my short commute and local I get 37.
In the air flow meter on bikes so equipped is a ambiant air temp sensor. They some times collect dust and that insulates it causing issues with air temp. K&N filters make it worse as the oil creates a film.
Clean that sensor. It's a little knub on the inlet side of the AFM. It's in the side of the air box on Motronic bikes.
1995 Morea Green K1100LT
Offline 2000rsv
Re: Fuel Range
« Reply #4 on: June 17, 2013, 10:19:41 PM »
Johnny,
It has new plugs, throttle body sync, and valve clearance checked.  I did not replace (or check) the air filter.  Will do that asap.
Ran a can of Seafoam through it in the first tank of the year.
Will let you know about the air filter.
J
Offline Tomnel141
Re: Fuel Range
« Reply #5 on: June 19, 2013, 05:10:42 PM »
It may not be a good idea to run a K bike out of gas. The fuel pump cools by sinking heat into the gasoline. When the gas runs too low to immerse the pump it gets hot. Big Brother sez this is doubleplusungood for the fuel pump. Also, fuel pumps are very expensive.
The idea of cooling the pump in gasoline is not as barbaric (or dangerous) as it may sound. You will either park the bike or buy fresh, cool gasoline in a fairly short time so it won't overheat the gas. This is the way most, modern fuel injected cars work.
  • My Motorcycle History 1. Whizzer motorbike 2. Jawa 150 3. Jawa 125 4. Harley Davidson 165 "Hummer" 5. Indian V-twin "80" 6. BSA XB33 7. Puch (Allstate) moped 8. AJS 20B 9. BSA Gold Star track bike 10. Suzuki 50MA 11. Tohatsu Selpet 12. Honda C110 13. Matchless G80CS 14. BSA Gold Star road bike 15. Lambretta scooter 16. JBe 125 17. Yamaha DT1 18. Yamaha DT250 19. Honda CX500 20. Honda GL650I, Grey 21. Honda GL650I, Red 22. Yamaha, DT250D, “Blue” 23. Yamaha, DT250B, “Red & White” 24. Yamaha, DT400E, “Yellow” 25. BMW, 1995 K75RTA
Offline 2000rsv
Re: Fuel Range
« Reply #6 on: June 26, 2013, 09:28:37 PM »
Replaced the air filter and ran about 1000 miles through the UP (Upper Peninsula Michigan) earlier this week.  Averaged about 42-45 MPG.  Think we are OK.
