Author Topic: Passenger Floorboards  (Read 6114 times)
« on: June 15, 2013, 11:36:04 PM »
greetings yawl...
i have been running a passenger peg lowering kit by mv verholen for a long time... all is well with that...
butts... the mickster has developed an issue with her foot that causes pain when she has her toes up in the twisties and while standing up... so our rides have been cut short from time to time so she could convalesce...
i gotts to looking around for a fix and found the illium works sportboards are perfect fit for the k1100rs... they use the oem pin and fit right in there...
the mickster used them today and gives them 1 thumb up... i have them on straight and she would like the front pointing out a little... they have adjustment to move the toe in and out with total movement approx 2"... i didnt have the 1/4 hex they provide so i didnt adjust them on the fly today butts i will set the toes out all the way tomorrow and see how it goes...
they are aluminum power coated gray... im thinking about rattle can black... i will report back here once she getts some more miles on them...
here is the info... 1 pair #11-700 PASSENGER FLOORBOARDS, LOWERED, R1100RT, R1150RT AND R1200RT
more later...
Re: Passenger Floorboards
« Reply #1 on: August 08, 2013, 08:46:26 AM »
yawl...
she gotts approx 1500 miles on these now... longest day was 460 miles over 16 hours... apparently these cured her foot pain and she reports no end of the day leg or foot discomfort... success... yeeehaaaaa...
Offline CRASH
« Reply #2 on: August 08, 2013, 12:59:33 PM »
How do they adjust?  SWAMBO is always looking for more comfort.  Of course, she also thinks if I let her put her feet on my pegs, that would be perfect.  :nono
- CRASH -
« Reply #3 on: August 08, 2013, 01:21:44 PM »
these are fixed height... the do have some that are height adjustable...
the only adjustment is the yawl...
you can move the toe in about an inch... so... if you are pigeon toad you would be able to get your soul on it fairly straight in relation to your pigeon toadness...
you can move the toe out about an inch... so... so... if you are duck toad you would be able to get your soul on it fairly straight in relation to your duck toadness...
i dont know if these will fit your moto... the fiche says you have the same passenger peg part number... guess its how the center stand hits it...
when i come over to replace my nitrous system and swap tiors you can give them a try...
