Author Topic: Oil leaking from water/oil pump (not out of weep hole)  (Read 6080 times)
Offline conybeare
  • Conybrick
« on: June 15, 2013, 03:35:27 PM »
Hello Motobrickers,
I replaced the seals in my water/oil pump last year and now I am getting an oil dribble out of the hole in the pump casing that the oil pressure switch wire is routed through. Am I correct in assuming that this is a problem with the seal between the oil pump casing and the engine block? No oil is coming out of the weep hole.
Thanks!
-CB
  • Saint Paul MN
Nothing :o
Previous: 2004 R1100S, 2009 Yamaha FZ6,1990 K75S, 1986 K75C, 1984 Honda VT500 Ascot, 1981 Suzuki GS250T
Offline Inge K.
Re: Oil leaking from water/oil pump (not out of weep hole)
« Reply #1 on: June 15, 2013, 04:32:20 PM »
You're correct about a leak between the oil sump and pump housing.
Keep the mounting surfaces clean, dry and oil free.
Use a sealant that can withstand the oil pressure (I've used Permatex black RTV).
Give the sealant time enough to cure, before starting the engine.
  • Norway
« Reply #2 on: June 15, 2013, 08:41:46 PM »
Also take note and be careful of the "half moon" oil channel on the block side as it's really easy to get too much sealant applied and block this opening.
I remember seeing a picture of this but can't remember where so I can't post it or a link at the moment, like all else it will come to me in time.........Old timers setting in...... :hehehe
Offline Inge K.
« Reply #3 on: June 16, 2013, 05:23:59 AM »
Good point, Scott.........when this hole is blocked, it could be the reason that a leak starts in this area.
  • Norway
Offline conybeare
  • Conybrick
« Reply #4 on: June 19, 2013, 04:04:10 PM »
Thank you very much, Inge and Scott!!
  • Saint Paul MN
Nothing :o
« Reply #5 on: June 19, 2013, 09:04:59 PM »
I have never been able to figure out where the weep hole is. Can somebody put up a picture that shows it?
Thanks, Bill
Offline Inge K.
« Reply #6 on: June 20, 2013, 04:26:35 AM »
Thanks, Bill
  • Norway
« Reply #7 on: June 20, 2013, 01:52:38 PM »
Thank you, Inge!                 Bill
