I'm on a wild goose chase for what might be an air leak on my 1994 K75S - I have hesitation off idle, and it seems to be because the engine is running lean, since pressing the starter right before blipping the throttle helps the hesitation a bit.
Anyway, I see a few mentions here and there of an evap system having been standard on California bikes. If i understand things right, this consists of a hose going from the fuel tank, trough a valve on the hose, which then goes to somewhere on the crank case. The hose would essentially channel excess vapors in the fuel tank into the crank case. Often these hoses have been removed, and the crank case opening has been plugged up.
I don't have the evap hose, but in the off-chance that my bike started out in California, I'm to figure out where that hose would have gone, to make sure it's plugged properly. Can anyone describe where to look, or even better, have a picture of it?
I have a long list of things I've done and places I've checked, so it would be fantastic if it turns out this was the problem.
