Author Topic: drive shaft stuck  (Read 12029 times)
dhanda
drive shaft stuck
« on: June 03, 2013, 12:44:20 PM »
hi all,
I have a problem with my k100rs 1984.
I thought I would lube the splines on the driveshaft on the diff end , when I pulled the diff off the whole shaft came with the diff, noticed the snapring had broken due to all the sliding move ment being done at that end. this maybe due to the shft being stuck to the diff end.
Any suggestions as to how I can free this off.
Re: drive shaft stuck
« Reply #1 on: June 03, 2013, 08:25:13 PM »
Almost sounds to me like the drive shaft and diff input splines are just about stripped and bound/wedged. Might explain why it won't come off.
« Reply #2 on: June 04, 2013, 12:39:37 AM »
greetings dhanda...
welcome to motobrick.com...
post up some photos so we can see whatca gotts going on...
cy7878
« Reply #3 on: June 04, 2013, 03:21:21 AM »
there is nothing holding the shaft to the diff end.  You just have to yank harder and pull.  I think the transmission end was not installed right the last time the shaft was out.  The ring can't really "break" because it is literally a circlip (#3) that is open ended.  The clip can loosen, but I doubt that happened.  Like others said, check the spline on the open end to see if that was a problem.
dhanda
« Reply #4 on: June 04, 2013, 06:14:08 AM »
Hi Guys ,
Thank you for you replies.
I have attached some pics showing the shaft stuck to the diff.
tried slide hammer and allsorts , loads of releasing fluid but no joy.
I will be taking it to a bmw bike shop today to see if they have anyway of getting it free.
As you can see the snap ring is broken and I presume all the slide action has been taking part at the gearbox end of the shaft
maybe the reason for the diff end becoming seized.
Offline mjydrafter
« Reply #5 on: June 04, 2013, 04:26:59 PM »
Just throwing this out there, but what if the wear pattern was great enough to allow the shaft to turn a bit and then lock up?
It's very odd, because as the parts wear they "should" get looser.
Maybe I'm not recalling the picture correctly, I will see if i can find it and explain a bit better.  BRB. :yes
1986 BMW K75c
Offline k75mark
« Reply #6 on: June 04, 2013, 10:51:18 PM »
Have you tried reattaching the wheel to the final drive?It might allow a little more leverage so that maybe gripping the driveshaft and twisting back and forth might break the bond free.
« Reply #7 on: June 04, 2013, 10:59:01 PM »
you know how moly kinda looks like jb weld... you following me here...
im thinking pb blaster me asap...
« Reply #8 on: June 04, 2013, 11:33:17 PM »
hmmm, most fascinating
cy7878
« Reply #9 on: June 05, 2013, 02:08:35 AM »
wow, I never thought the circlip can break.  I was wrong.
dhanda
« Reply #10 on: June 05, 2013, 03:47:49 AM »
hi all
took it to the bmw bike shop , they tried hot air gun on the shaft and slide hammer attached to the u-joint , but still solid no movement.
today taking it to a place where they rebuild shafts and u-joints, hope they can free it off.
dhanda
« Reply #11 on: June 05, 2013, 09:11:20 AM »
Finally got them apart , took 3 of us to do it.
Used big slide hammer and heat.
Offline mjydrafter
« Reply #12 on: June 05, 2013, 09:48:08 AM »
Looks like it could use a spline lube... :yow :yes
Glad you got it. :clap:
1986 BMW K75c
cy7878
« Reply #13 on: June 05, 2013, 10:14:27 AM »
before you put things back, make sure the mating surfaces are smooth to avoid leaks.
The dow (spelling?) looks bend and may need replacement.
dhanda
« Reply #14 on: June 05, 2013, 01:41:40 PM »
hopefully I will put new dowels in before assembly but just spent an hour cleaning the surfaces and splines and there looking in good condition.
bought some Castrol moly paste for the splines.
cy7878
« Reply #15 on: June 05, 2013, 03:40:38 PM »
I mixed Wurth 3000 grease with the moly.  It is super sticky.  If you're near by san Diego, be happy to give you some.  The can I bought was 4oz which will probably last me my life time.
dhanda
« Reply #16 on: June 05, 2013, 04:43:37 PM »
thank you for you generous offer but I am the other side of the pond :bmwsmile
