Author Topic: ABS Shims and a cryptic scan job  (Read 3334 times)
Offline tsbt
« on: May 28, 2013, 10:48:03 AM »
Need to replace my abs sensor shim on the front it's squealing like a pig obviously too snug. Can't seem to decipher which size shim I should order from the K100rs manual microfiche because it's all pixelated. Any idea what size is standard? I feel like 0,100mm might be the right measurement but I'm not sure.
92 K100RS 4V
75 KE125
Offline Grim
Re: ABS Shims and a cryptic scan job
« Reply #1 on: May 29, 2013, 12:25:11 AM »
Use the shims off the back to experiment till you find the right combination then order.
1995 Morea Green K1100LT
