Author Topic: Making rear turn signals double as brake lights  (Read 10334 times)
« on: May 21, 2011, 01:04:07 PM »
I'm running a Kisan Signalminder SM-6 because that lets you run LED turn signal bulbs without getting the hyperflash that the stock flasher relay would give you.  Since LEDs draw a very small current that means that I can use small and inexpensive PCB (printed circuit board) relays that I get on Fleabay for about a buck a piece.  I solder the wires to the pins, then wrap the relays in electrical tape and then fill that up with five minute epoxy to make things permanent and waterproof.
Circuit design attached.
