Author Topic: Transmission Seals à la carte  (Read 5918 times)
Offline tsbt
« on: May 09, 2013, 04:56:20 PM »
Going back in to replace a couple of transmission seals.
92 K100RS 4V
75 KE125
jeffhestand
Re: Transmission seals
« Reply #1 on: May 12, 2013, 10:37:47 PM »
which seals.... i currently have my tranny out having just loctited the grub screw . Wondering which seals you were doing since i have oily residue below the clutch pack on the bell housing. Some say replace the clutch nut oring some say a main seal. The clutch pack is intimidating me right now so im not sure what to do. Any advice?
Offline tsbt
« Reply #2 on: May 13, 2013, 09:34:51 AM »
There are 3 seals in the transmission to my knowledge, two on either ends of the drive shaft and one on the output shaft - I might need to change bearings while I'm in there we shall see.
I replaced the clutch o-ring and main seal on mine, it was leaking everywhere, the main seal was the toughie I had to fashion a custom tool to install it: http://www.motobrick.com/index.php/topic,2652.msg15008.html#msg15008
92 K100RS 4V
75 KE125
Offline tsbt
Re: Transmission seals part deux
« Reply #3 on: May 31, 2013, 08:34:52 AM »
Scalpel...
bleeding from the input
in the bucket...smells like sulfer so it's definitely the transmission...
everything looks okay at first glance...
then again, I'm not really sure what I'm looking for...
so I'm here to change three seals, input, output and needle...sure is dark in here, bearings feel solid...
shifter is always super sticky while shifting, but I hear you really gotta give K's the boot when shifting, probably normal...
a few more random photos so I can inspect later...
The transmission is just resting on a bench I don't really have anything to stabilize it so i'll see if that's an issue as I get further along...I also need a bearing puller, and I hope to get by without any special super-duper-bmw-tools that don't exist anymore... :beehive:
92 K100RS 4V
75 KE125
Offline lunchbox
Re: Transmission Seals à la carte
« Reply #4 on: June 01, 2013, 03:00:00 AM »
There is also a seal on the shaft for the toe shifter and a seal on the clutch pushrod. I used a socket of the corresponding size for tapping in each seal, no leaks two years later.
'92 K100RS
cy7878
« Reply #5 on: June 01, 2013, 10:28:30 AM »
and the cover next to the output shaft is also recommended to be changed.
Offline tsbt
« Reply #6 on: June 01, 2013, 10:37:18 AM »
Thanks, would've missed that.
And this as well. Only want to do this once!
92 K100RS 4V
75 KE125
