Author Topic: LEDified front and rear reflectors  (Read 6407 times)
« on: May 21, 2011, 09:03:34 AM »
I bought some yellow LEDs for the front and some red ones for the rear.  They come off of a roll so if you order 4 3-LED strips you actually get one strip of 12 that I cut down into two strips of 6.  The LEDs are mounted on film so they can be sandwiched between the reflector and it's mounting base.  The LEDs themselves are raised so I used my Dremel cutting wheel to make holes for them in the back of the reflector. Then I sealed/reglued them with marine contact cement to keep them waterproof.
The pictues are a tad blurry due to the lighting conditions and using a point and shoot camera but you get the idea:
Rear:
Front:
Both:
IMO, they look even better in real life.
Here's links to the LEDs I used:
Red LED strips
Amber LED strips
I further modified them later so that they flash off when the turn signals flash on so they double as both side running lights and turn signals.
Offline acftfliehr
Re: LEDified front and rear reflectors
« Reply #1 on: November 25, 2014, 01:15:42 PM »
Just Picked this up on the KBikes section on the Yahoo groups...
Great Job and thanks for the tip especially this time of year!!
Offline enb54
« Reply #2 on: December 17, 2014, 11:04:45 PM »
Obviously made a mistake responding here, sorry! Thank you!
I'm going to try this great idea out as soon as my shop gets a bit warmer...
  • Red Deer, AB
Eric
Then-1966 Suzuki X6 Hustler, 1987 BMW K100RS, 1997 Suzuki GSF600 Bandit, 1991 BMW K75 RT
Now-1974 Honda CB125S, 2015 Honda Grom (MSX125)
