Author Topic: i dont want to miss anything!?!?  (Read 5392 times)
jeffhestand
« on: May 05, 2013, 10:04:43 PM »
Finally got  the chance to tear into my tranny on my 85 K100 to fix the pesky grub screw. Everytime i work on this bike i am AMAZED how easy it is to work on. Anyway, yanked the starter  and plan on going thru it. And will be lubing all splines that i can get to again but..... if there is anything else i should be servicing or at least taking a look at PLEASE lend some advice while i have her apart. I plan on keeping this one a LONG time so i want to do it right. Thanks !!
Offline pallum
Re: i dont want to miss anything!?!?
« Reply #1 on: May 07, 2013, 12:10:43 AM »
Pulling the clutch pack to replace the clutch nut o-ring is a start. If you're thinking of taking care of any frame rust, the time to do it is now because the transmission really gets in the way of painting the usual spots. There's always a million other things to do but those are my big picks for when the transmission is off.
  • Federal Way, WA
jeffhestand
« Reply #2 on: May 07, 2013, 11:26:33 AM »
is pulling the clutch pack pretty straightforward once i have tranny out. Also is this oring a failure issue? I do plan on taking care of the the frame rust as well. Any other advice? Thanks !
Offline Kyle10
« Reply #3 on: May 07, 2013, 11:55:17 AM »
- Pull apart your starter (easy) and with an eraser or really, really fine emery clean off the brass on the spindle. Better conduction.
- Replace the starter bushings. They're probably quiet worn.
- Use 'Guard Dog' (http://www.guarddogmoly.com/prod-moto.shtml) to lube your splines. Rub it in hard; the moly bonds with the metal. Best stuff I've found so far.
- Renew the dogs in the alternator. If they're original they've probably lost their effectiveness via shriveling up.
- Upgrade your ground wire with a 14 gauge wire. The original is as thick as a pencil lead.
- Clean, scour your trans. (brass wire wheel, pine sol, whatever) and spray it with this (http://www.gibbsbrandlubricant.com/) before reinstalling. It 'quenches' the metal and will keep your tranny clean looking and less a dirt magnet.
Jeez, I sound like a walking brochure...
1985 K100rt
1983 Honda VF750F
The other 2% made it home.
JamesInCA
« Reply #4 on: May 07, 2013, 05:19:27 PM »
Wow, that Gibbs looks like magic stuff!
"It CLEANS, PROTECTS, LUBRICATES, CONDITIONS and PENETRATES."
and it's "clinically tested."
You sure this stuff is for metal?
Offline Kyle10
« Reply #5 on: May 07, 2013, 08:41:26 PM »
Yep. It's great. It was invented by a guy who worked on Harleys. Metal, rubber, plastic. Not kidding; the stuff is fandamntastic.
You can find vids for it on YouTube if you need convincing. I spray it on my engine periodically and it really makes it look great. Not a gummy coating; the metal actually 'likes' it.
1985 K100rt
1983 Honda VF750F
