Author Topic: Leaking tank  (Read 4029 times)
Offline Fossil
  • '91 K100rs4V caretaker
Leaking tank
« on: April 26, 2013, 04:18:45 PM »
Found crud in tank and cleaned it out. While doing this I discovered blistered paint at bottom edge of tank and under that I found a previous repair. I want to use a sealant (epoxy?) that you coat the inside of tank with. Does anyone have a suggestion which product to use. I don't want to cause any restriction around the pump baffle. Thanks
How can you be lost if you don't give a crap where you are?
Offline tg4360
Re: Leaking tank
« Reply #1 on: April 27, 2013, 02:28:05 PM »
Caswell is your friend.
I did the bottom of and up the sides of my LT tank.   The layer is about a quarter inch thick on the bottom of the tank.
Worked well.
Tony G
'79 XS750 "The Triple"
'72 A65T "The T-Bolt"
'68 B25 "The Blue Bike"
Offline Fossil
Re: Leaking tank
« Reply #2 on: April 28, 2013, 02:22:38 PM »
Thanks for the tip. I'll give them a call tomorrow. This brick may fly before too long.
