Author Topic: Works Performance shock needs maintenance  (Read 3446 times)
Offline mrcasual666
« on: April 26, 2013, 11:50:12 AM »
Just noticed the Works Performance rear shock on my '92 K75S is dribbling fluid. I'm assuming a seal needs to be replaced. Works quoted me around $110 to replace the seals and the shaft, if needed. Seems reasonable. The problem is it takes 3 weeks, plus a week of shipping time each way from NYC to Canoga Park, CA.
Is there a shop in the NY/NJ/CT area that could do the work, or does it need to be sent back to Works Performance? Or is it possible to do yourself?
Thanks!
Pete
Pete
1992 K75S (48k mi)
Brooklyn, NY
Offline mrcasual666
Re: Works Performance shock needs maintenance
« Reply #1 on: April 29, 2013, 06:14:54 PM »
Called around and it doesn't seem like anyone but Works can do the maintenance. I swapped the Works shock out with the original BMW shock over the weekend, which was pretty simple. The trick was setting the incoming shock to the softest setting so it was short enough to fit into place.
I sent the Works shock to CA today, $12 for two day deliver with USPS flat rate shipping. Works says it takes about 3 weeks to turn it around, $75 for new seals, another $45 if it needs a new shaft.
In the meantime, the original BMW shock seems like its in decent shape, except the rubber guide at the bottom is cracked pretty bad. Is that a deal breaker?
Pete
1992 K75S (48k mi)
Brooklyn, NY
