Author Topic: what is this shock off???  (Read 6183 times)
Offline racinrich
« on: April 24, 2013, 07:24:31 PM »
the post was1995 k1100lt parts the shock I bought does not look like either lt shocks I have now
1 inch shorter
not a progressive wound spring
no rebound adjustment
spring guage is thinner
only 3 spring preloads instead of 5
shouldn't  1993 to 1995 be the same? :dunno
1993 k1100 lt silk blue
des plaines ill
USA
Offline racinrich
Re: what is this shock off???
« Reply #1 on: April 24, 2013, 07:32:55 PM »
pics in yard sale 1995 k1100lt parts by fireman
des plaines ill
USA
« Reply #2 on: April 24, 2013, 08:27:00 PM »
I posted in the other thread but, I measured mine that came off of my '95LT and it was 15" center to center of the bolt hole. Mine only has 3 settings for the preload. The factory shock on my '97 only had 3 preload settings a well.
If yours has 5, it may be the odd ball non factory issue.
Offline Fireman
« Reply #3 on: April 24, 2013, 09:38:04 PM »
Rich,
As far as I know it's off my 1995LT, looking through my stuff here there is another spring I am not sure if it is for that shock--- if you would like me to send it to you I will--- no cost. If it will not work for you email me back for a refund. ildahl@comcast.net
Thanks Lance
Offline racinrich
« Reply #4 on: April 24, 2013, 09:43:08 PM »
is the spacing between the coil the same or does it look closer at one end
des plaines ill
USA
Offline Fireman
« Reply #5 on: April 24, 2013, 09:51:00 PM »
I am at the fire house today I will post the length and specifics tomorrow.
Lance
cy7878
« Reply #6 on: April 25, 2013, 11:42:48 AM »
the shock I saw looks kinda like the one I took off my K100RS.  It's 14 inches hole to hole.  3 spring adjust points.
Offline Fireman
« Reply #7 on: April 25, 2013, 11:55:38 AM »
Rich,
Here is the other spring that was in my box of parts-- it's 11 1/4" long. It's yours if you want me to send it. Maybe the previous owner changed springs to get a different height or softness. I will ship this out if you would like it Rich.
Thanks Lance
