Author Topic: Hesitating at speed~  (Read 5157 times)
Offline Spitfire
« on: April 21, 2013, 06:03:58 PM »
It's my very loved 1990 k75- rides well except for the hesitation when up shifting-I have to almost "catch the bike up" with the throttle... and recently a very noisy fuel pump(?) Just emptied and cleaned the tank- maybe an air bubble in the fuel system- would that match the symptoms? Should I be able to hear the fuel pump anyways?
  • Taos, NM
  • 1990 K75
Spitfire Forge
Re: Hesitating at speed~
« Reply #1 on: April 21, 2013, 10:57:07 PM »
Quote
So it's more noisy than it used to be?
« Reply #2 on: April 21, 2013, 11:21:01 PM »
catch the bike up... slipping clutch most prevalent in higher gears whacking the throttle...
Offline Spitfire
« Reply #3 on: April 22, 2013, 11:56:55 AM »
Yes it's a bit noisier- I don't remember being able to hear the fuel pump through my helmet. I did just clean the tank- maybe the pump is still priming(?) :dunno2:
  • Taos, NM
  • 1990 K75
Spitfire Forge
JamesInCA
« Reply #4 on: April 22, 2013, 12:41:28 PM »
I can just hear mine faintly through the helmet, just a subtle but clear, constant whine or whirr from the tank. Does your noise sound different?
It would seem low or inconsistent fuel pressure might cause hesitation, no?  Harbor Freight has a relatively cheap fuel injection pressure gauge setup. (If you get one, be sure you get the one for fuel-injected engines, not the carb one. Completely different measurement range.)
Everything should be primed and pressurized once the engine is running. Maybe it'll be rough for the first few seconds running. But when I've had the tank and/or fuel hoses off, it's usually just cranky about starting - once it's started, it's fine.
« Reply #5 on: April 22, 2013, 06:51:34 PM »
Last time the fuel filter was changed?
1957 K1100LT 0302044 (R.I.P.)
