Author Topic: refitting fuel level sensor  (Read 4542 times)
grant71
« on: April 11, 2013, 07:59:37 AM »
hello. i am refitting a newly bought used fuel level sensor in my 86 K100 RS.advice i need pse is: does the round rubber seal( its new ) need any kind of gasket type sealant to make the fuel sensor plate and fuel tank connection leak proof. thanks
Re: refitting fuel level sensor
« Reply #1 on: April 11, 2013, 04:32:05 PM »
The gasket (o-ring) itself should be enough, no sealant needed.
grant71
« Reply #2 on: April 11, 2013, 05:32:21 PM »
thank you Inge
grant71
« Reply #3 on: April 13, 2013, 12:03:16 PM »
This pm i started re fitting my fuel pump and the rest inside the tank. For a 1 st timer what an exacting job. I have a small problem. I cannot get the thin plastic tube  from top side of tank to the bottom of the pump next to the  small sieve like filter on. Is it a train smash if i leave it off ?
