Author Topic: Horn relay??  (Read 7230 times)
Tom05301
Horn relay??
« on: April 07, 2013, 12:29:14 AM »
Greetings Brickers,
I'm at the beginning of an electronics upgrade, including installation of a 50 amp alternator from Frankenduck, a headlight relay kit from Eastern Beaver, and some LED driving lights. As long as I've got bits all over the garage, I wondered if I should do something about the horn circuit. At some point I will put on something you can hear over the cat's purring, so  I'm wondering if the stock relay and wiring can handle the upgraded equipment on the market. Ancillary questions include would it make sense to beef up the wiring or add another relay after the BWM relay so I can pump some serious amperage to the horns yet to be installed. I'm thinking freight train or equivalent.
Thanks,
Tom
Offline argent brick
Re: Horn relay??
« Reply #1 on: April 07, 2013, 12:38:26 AM »
There is a horn available called The Banshee Horn that I have heard good things about.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Re: Horn relay??
« Reply #2 on: April 07, 2013, 01:27:16 AM »
Tom05301
Re: Horn relay??
« Reply #3 on: April 08, 2013, 10:22:35 PM »
Thanks for the reference material. I still don't know if my stock wiring and relay will handle a louder horn. I guess I'll figure it out while the tank is off.
Re: Horn relay??
« Reply #4 on: April 09, 2013, 02:02:29 AM »
Stock wiring is probably fine. The relay certainly is.
You will need a bigger fuse. Shared with a few other things: Fan, Indicators(I think. When I blew mine, they went wonky). I just put a 30 amp one in, don't want to worry. I blew a 15 or 20 amp fuse when I had to honk while passing on a hot day. I guess the fan was on, and the stebel nautilus used up the rest of the overhead.
Tom05301
Re: Horn relay??
« Reply #5 on: April 12, 2013, 07:51:51 PM »
My experience may vary.   8<) Bigger fuses, bigger horns, wuhoo!!
Thank you,  wmax351
