Author Topic: K11 pig to fire up  (Read 9043 times)
Offline k11pfc
  • From Portsmouth UK and Riding a 1994 K1100rs
K11 pig to fire up
« on: March 28, 2013, 08:18:48 AM »
My 1994 k1100rs, 31k on the clock is a pig to start if its been left, even overnight especially in the cold, it always catches eventually but just doesn't fire quickly and certainly much longer than it should be, the fuel pump works I keep the 'choke' at the halfway point, battery is always fully charged, I leave the throttle alone as always but it's just a pig to fire up. Any ideas?
Play up Pompey
Offline Snowy
Re: K11 pig to fire up
« Reply #1 on: March 28, 2013, 01:40:23 PM »
In cold weather, push the "choke" all the way to the stop. When the engine fires, let the "choke" stay on the halfway point.
What's the engine idle speed when its warmed up?
  • Marlborough, UK
Offline k11pfc
« Reply #2 on: March 28, 2013, 01:57:21 PM »
It runs just at 1000 rpm, it runs very sweet it's just a bit of a pig to start
Play up Pompey
Offline pallum
« Reply #3 on: March 28, 2013, 09:24:18 PM »
I had similar problems starting below freezing. I checked valve clearances and found 3 to be tight beyond spec. Tight valves are a suspect for any engine with hard start ups, too. All you need is a 10mm socket, needle nose pliers, a set of feeler gauges, a little rtv sealant and about an hour!
  • Federal Way, WA
« Reply #4 on: March 29, 2013, 01:07:57 AM »
greetings k11pfc...
sounds like it need to be ridden hard on a regular basis... a 94 with 31k kilometers... i think its being a drama queen from lack of attention...
motobricks aints no garage queens... they must me ridden hard and often to be happy...
Offline Bassv
  • Ride it like you stole it
« Reply #5 on: March 29, 2013, 09:19:34 AM »
Just like my girlfriend!
K75RT 1991
« Reply #6 on: March 29, 2013, 09:57:24 PM »
 :2thumbup: :hehehe
Offline k11pfc
« Reply #7 on: March 31, 2013, 03:40:58 PM »
In my defense I bought it 18 months ago with 7k miles on it!! Anyway someone suggested flicking kill switch a few times before starting in case the filter is a bit dirty, so I tried this and its started fine the last 2 days in temps of around zero so hopefully I'll change the filter and it'll be fine. Hopefully.
Play up Pompey
Offline KCinSB
« Reply #8 on: April 02, 2013, 09:59:23 AM »
Wow,.......  I'd be a Pig to start around zero degrees TOO !!!
  • Santa Barbara, CA
  • SOLD
Offline bocutter Ed
« Reply #9 on: April 02, 2013, 10:31:57 AM »
That would be centigrade in the UK, or 32F. That's near the temps we're having in Toronto this time of year (-3C this AM). Nice riding weather. Went for a 50km(30 miles) ride north to my sister's place for Easter dinner on Sunday at about 8C(46F). Wasn't cold even at 135kph(84mph).
  • Toronto, Canada
Offline JamesInCA
« Reply #10 on: April 02, 2013, 12:18:22 PM »
How old is the battery? Even if it's reading as fully charged, it might not be able to deliver the full current required for a good clean start.
My sketchy winter starting cleared up last year when I replaced the battery.
