Hello,
I have a recently purchased 1986 K100RS.
Everything is fine after replacing lots of aged things and obtaining a "roadworthy certificate" ( as it is called in Victoria, Australia ) .
I have discovered an odd problem.
On a hill, stopped at traffic lights I can feel the front brake lever give a little, like a creeping feeling. It is more noticable when the bike has been ridden for a while and is hot.
There are no signs of leaking fluid from the Master cylinder or either front caliper.
The brake lines look original so they are probably 27 years old.
I read "somewhere " old lines on these bikes get soft and feel spongy. Could this be the give I feel in the brake lever ? Maybe the line from the master cylinder to the splitter thing is getting hot from the engine and going soft.
Or, as advised elsewhere , have one of the internal seals inside the master cylinder developed a leak ?
I've spent a little fortune so far. I might sound cheap but in the interim I would like to avoid fixing it all at once
Thanks
Stuart
Melbourne, Australia .
