Author Topic: Battery Terminal Home Built Modification  (Read 3374 times)
Qdude
« on: February 11, 2013, 07:19:51 PM »
The PC 680 has flat mounts where the OEM has vertical mounts. I am going to create a 90 degree brass flatbar converter.
I bought Brass Nuts, Bolts & Washers and an all brass door hinge that I will cut up to create the converter's.
Would there have been a better material to use than brass?
I know that you can buy the parts pre-made online, but it would be easy enough to make them, and I have the materials now.
I also found square rubber furniture foot pads to shim the battery holder with so that it does not short out.
Should I not proceed with the brass.
Re: Battery Terminal Home Built Modification
« Reply #1 on: February 11, 2013, 08:22:05 PM »
Sounds fine to me. Anything should work, the terminals are usually lead.
Qdude
« Reply #2 on: February 11, 2013, 11:29:38 PM »
Brass battery posts are done.
Good and insulated as well.
On to bigger headaches.
