Author Topic: Early K100 TBs: What are these parts? Purpose/function?  (Read 6261 times)
« on: February 10, 2013, 08:14:55 AM »
See attached.
Offline frogy
Re: Early K100 TBs: What are these parts? Purpose/function?
« Reply #1 on: February 10, 2013, 08:30:25 AM »
#11 looks to be a "one way valve", not sure about other piece.
2002 R1150RT
1985 K100 Naked
Craig
« Reply #2 on: February 10, 2013, 08:36:32 AM »
If I remember correctly this vacum switch would advance the timing a few degrees to improve fuel economy,
 but it probably did close to nothing....since it was discarded after a short time.
It grounds pin #15 at the ignition ECU.
Inge K.
« Reply #3 on: February 10, 2013, 09:49:59 AM »
Thanks, Inge.
I figured since it had a switch that it's wires had to go somewhere.  Interesting that they didn't change the L-Jetronic when they got rid of it.  Probably just easier/cheaper to keep the same circuit design and leave it as an unused pin though.
« Reply #4 on: February 10, 2013, 05:43:41 PM »
Inge is correct. It bumps the timing a bit at lower rpm, low load (high vacuum).
Do you know where it connects on the K75? I could use that to selectively bump the timing with the megasquirt system, without having to add full spark control.
« Reply #5 on: February 10, 2013, 05:58:15 PM »
Early K100's only.
« Reply #6 on: February 10, 2013, 06:04:08 PM »
K75s never had it, only 85 and earlier K100s.  It grounds pin 15 on the ICU. You could try that on a K75 ICU and see what happens. :dunno2:  Might be interesting to open up the ICU and see if that pin's connected to anything.
« Reply #7 on: February 10, 2013, 08:49:03 PM »
I might give that a go. I don't see why they would change much on the system.
