Author Topic: "New" K1100RS owner in Sweden  (Read 15282 times)
jeverett486
« on: January 20, 2013, 03:51:09 AM »
Hello everybody from Sweden.
Today was quite exciting: I delivered my 2010 F650GS to its new owner, then two hours later, I received my "new" 1993 K1100RS.
This isn't my first K by any means, but it is my first K1100RS.
Here she is just after arrival:
Here she is an hour-and-a-half later:
I'm not sure what I'm going to do with her, but finding out what surprises lie under the surface is always my first action.
I'm thinking of ways to put her on a diet, without ruining her looks.
All suggestions are appreciated.
Thanks and rubber side down (even in the snow)!
Jay
Offline Crapdealerbob
Re: "New" K1100RS owner in Sweden
« Reply #1 on: January 20, 2013, 08:21:39 AM »
Welcome!  I wouldn't change a thing, she is a beauty!
Crapdealerbob
Wickenburg, AZ
1991 K100 RS
jeverett486
« Reply #2 on: January 20, 2013, 10:58:15 AM »
Photos can be deceiving... she definitely needs some TLC.
Offline Lawrence
« Reply #3 on: January 20, 2013, 12:43:06 PM »
Welcome!  I agree that she's a lovely bike.    :2thumbup:   Please don't do anything too radical.  How many km. are on the clock?
1985 K100RS
1982 Laverda Mirage 1200TS
1983 BMW R100RS
jeverett486
« Reply #4 on: January 21, 2013, 01:17:36 AM »
Thanks, Lawrence.
I think my extent of radicality will be to try and lose some weight.
I would like to make, or find, a new tail section out of aluminum with an integrated saddle, LED turns signals and brake light; something akin to cafe racers.
I did think about removing the fairing completely and have a round headlight instead, like the K75C. But I like the looks and protection of the fairing, so it will probably be the remaining piece of fiberglass on the bike.
I have removed the mirror and integrated turns signal. I will most likely replace them with bar-end mounted LEDs.
Other than that, no bags, extra lights, or extra fuel cell. I want a lean, mean commuting machine.
I will keep everyone posted with pics.
Best regards,
Jay
BTW: It's a former police bike with 125.000 km on the clock.
Offline Freelancer
« Reply #5 on: January 21, 2013, 01:35:34 AM »
*snip*
Jay
Hi Jay,
Nice score on the '93 K1100 rs.
As to your question about weight reduction, There are a few things you "can" do, thoough some of which will get the technologically dependent in an uproar. Note that I am not advocating nor dicouraging any of the following. They are just ways of dropping or not unwittingly adding weight.
That said, here goes:
First, an aftermarket non-cat exhaust will save a few pounds. If you find someone to custom make you a set, the weight savings can improve through use of exotic materials.
Second, (Getting ready for the safety'crats to scream :nono) Removing the ABS completely will drop  25 lbs+/12 kilo+ :2thumbup: from the bike. Your decision on how much you value the abs here.
Third, Be careful on after market seats. My Corbin is about 3x the weight of my old stock seat. Thing is, most afermarket seat pans are much heavier than the stocker.
Personally, I recommend having Sargent recover a factory seat pan here and be happy to riding away more comfortably and at the same weight.
Fourth, aftermarket peg kits can save a few ounces to a pound but can also drastically change how the bike looks depending on what is done with the mounting plates.
Fifth, you can ditch the factory luggage and mounts in favor of modern soft luggage. This might save a pound when ridding without bags.
Sixth, You can ditch the heavy bar ends if vibration numbness of the hands doesn't bother you. :laugh
Seventh, You can trim the rear fender or eliminate it.
From this point on, you start getting into things that
A) will profoundly change the appearance of the bike, and
B) Will get very expensive very quickly.
Things like:
Machinging in the back of the trans case and swingarm to save a few ounces(Maybe a pound)
Removing bodywork
Building a custom intrument cluster(You can save about 2-3 pounds on the cluster)
Custom lightweight rims
Replacing all steel bolts and screws with titanium ones
Custom wiring harness
As I said, these last ones are probably a bit excessive but who knows, there might be one or two things that you decide to or might be rich enough to do(Cough cough-Titanium hollow boltscough) :yes
Hope these ideas help.
Later,
Freelancer
1991 K100RS
jeverett486
« Reply #6 on: January 21, 2013, 05:37:33 AM »
Hi Freelance,
Thanks!
As to your question about weight reduction, There are a few things you "can" do, though some of which will get the technologically dependent in an uproar. Note that I am not advocating nor discouraging any of the following. They are just ways of dropping or not unwittingly adding weight.
I appreciate all input.
Not sure what the authorities would say about cutting out the cat. Everything must be CE marked here. But I am aware how much the orig exhaust weighs.
Second, (Getting ready for the safety'crats to scream) Removing the ABS completely will drop  25 lbs+/12 kilo+ from the bike. Your decision on how much you value the abs here.
I've driven enough to know most of the pluses and minuses of ABS. In this case, I am thinking weight and simplicity is the solution in this case.
Third, Be careful on after market seats. My Corbin is about 3x the weight of my old stock seat. Thing is, most aftermarket seat pans are much heavier than the stocker.
I plan on creating a new tail section with integrated custom seat. So I don't have to worry about a seat pan.
I'm thinking very seriously about designing new footplates, possibly rear sets. RAASK is a Swedish company, so I have a chance to speak with them directly.
Already gone.
Already gone.
Already gone. Will look for some hugger option.
I want to keep much of the look. The KRS is a beautiful bike.
I bought cheap so I have a little budget, and I do most things myself, but I don't want to go overboard.
Things like:
Machining in the back of the trans case and swingarm to save a few ounces (Maybe a pound)
I'm trying to avoid dismantling the engine and driveline. However, I am seriously thinking about replacing the intake manifold and airbox with something. But I don't know what yet.
Removing bodywork
Already gone.
Since everything's electronic, I am definitely thinking about options for instruments.
Out of my budget.
Reaplacing all steel bolts and screws with titanium ones
Out of my budget.
It will be, when I'm done!
Definitely.  :2thumbup:
BR/ Jay
Offline BIG D
« Reply #7 on: January 21, 2013, 05:56:48 AM »
 cool shades
Hi Jay welcome,
Nice looking machine you have there and yes I can understand your thinking about having a look to see if there are any problem areas.
BIG D
jeverett486
« Reply #8 on: January 21, 2013, 07:51:31 AM »
cool shades
Hi Jay welcome,
BIG D
Thanks for the welcome, BIG D. Yes, it's always interesting to tear into something and discover "what you really bought".
More pictures soon.
She's getting lighter everyday:
jeverett486
« Reply #9 on: January 26, 2013, 02:29:02 PM »
Getting lighter. ABS removal next step.
Qdude
« Reply #10 on: February 12, 2013, 02:35:03 AM »
Looks like a great project.
Your focus is obviously about losing weight.
What are you going to do about cosmetics?
Any plans for paint?
