Author Topic: ABS lights  (Read 4633 times)
Offline argent brick
ABS lights
« on: January 06, 2013, 02:44:46 AM »
When I started my brick today, the ABS lights did not go out. They continued to flash while I was riding and I figured that my ABS system is toast.
The next ride, they worked just fine. Anyone have suggestions or ideas?
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Re: ABS lights
« Reply #1 on: January 06, 2013, 04:15:16 AM »
ABS brains are sensitive to low voltage.  Take your battery to an auto parts store and get it load-tested for free to see if it's on it's way out.
Re: ABS lights
« Reply #2 on: January 06, 2013, 06:58:26 PM »
I hope it is not on it's way out. Battery was put in last summer. Any other ideas, guys?
Lynn
1976 R60/6 RIP
Re: ABS lights
« Reply #3 on: January 06, 2013, 07:39:11 PM »
If you're not careful with the wiring for the ABS sensors then they can chafe on the wheel rubber, rub through and fail.
Get a 12V LED at Radio Shack and check the fault code.  That will help you track down where the problem might be.
