Author Topic: Leaking Fork Seal  (Read 7333 times)
Offline argent brick
Leaking Fork Seal
« on: December 04, 2012, 01:32:57 AM »
My left fork seal has started leaking. How hard is it to take care of it?
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Offline 552255
Re: Leaking Fork Seal
« Reply #1 on: December 04, 2012, 11:55:17 AM »
Try a thin piece of metal (feeler guage thin) and carefully go around and 'under' the seal to attempt to dislodge crud...otherwise replace.  Sure there is a write-up (lieberry?) here.  Its a good bit of work.
'97 K1100LT-SE
'96 k1100RS-SE
« Reply #2 on: December 04, 2012, 04:04:54 PM »
Thanks, the feeler gauge idea sounds like something that I will try.
Lynn
1976 R60/6 RIP
« Reply #3 on: December 04, 2012, 07:59:52 PM »
Seals aren't rocket science, just a bunch of busy work. :yes
Rick G
« Reply #4 on: December 04, 2012, 08:51:58 PM »
I haven;t had any success with using a feeler gauge but I think it depends if the seal is shagged or the grasshopper tried to hide under it to get out of the breeze.
« Reply #5 on: December 05, 2012, 01:04:17 PM »
Replacing seals was the first repair I did when I got my bike. It's not hard but it does require some ingenuity and time. There are several screws that can be stripped fairly easily, or might have been stripped by a previous owner. It was good to clear out the sludge in the bottom of the forks though.
Offline Jumpin Jimmy B
« Reply #6 on: December 05, 2012, 10:22:52 PM »
Drop the fork legs. Take them apart & clean well. If it's not been done you may be amazed at all the crud in there.
 Install the new seals AND fork boots !  Rancho #1952 shock boots work REAL well.  Keeps the crude and rain out.
 Has worked for me for over 25,000 miles.
I'd rather be riding.
« Reply #7 on: December 06, 2012, 12:34:26 AM »
What is so special about Rancho shock boots? I figured boots were boots. How different can they be?
Lynn
1976 R60/6 RIP
Offline robleyd
« Reply #8 on: December 06, 2012, 12:56:39 AM »
They're cheap - $5.48 each from Amazon - and they fit with minor trimming of the top of the boot. Of course, you can adapt boots from other model BMs but be prepared to dig deeper in the wallet.
Motobrick member #70
1996 K1100 LT
1969 Triumph Bonneville
« Reply #9 on: December 08, 2012, 09:14:05 AM »
yah der hey, they is cheap but look good!
 I used hose clamps painted with truck bed liner to hold them onto the fork leg. My bike is a dark graphite color and it looks better this way I think. The top part of the fork boot fits very snug to the fork tube, no clamp needed.
