Author Topic: Alternating Brake Light Strobe  (Read 5309 times)
« on: October 29, 2012, 12:25:45 PM »
Here's a DIY way to make your tail and brake lighting stand out much better without spending a lot of $$$. (Due to the limitations of YouTube the strobing is a little choppy in this video but you get the idea.)
Step 1) Do the Easy, Inexpensive Tail Light Upgrade
Step 2) Obtain a brake light strobe. (a.k.a. flasher) There's a few varieties out there which can be had on Fleabay for <$20 shipped.  The one I used for this bike is one that strobes eight times and then goes solid. I'd recommend getting the smallest one you can find so it fits inside of the area behind the tail light lens.  If its too big for that then you'll need to drill some holes for the wiring in the tail cowl "wedge" and install it in the tail cowl storage compartment.
Step 3) Buy or make a normally closed relay. Here are your options:
Buy: Buy a standard Bosch type relay with five terminals.  Make sure it has an "87a" terminal as some five pin relays have two 87s instead of an 87 and an 87a. (The 87a is the normally closed terminal.)  These are kind of bulky so it probably won't fit behind the tail light lens so you'll probably need to drill some holes in the tail cowl "wedge" and install it in the tail cowl storage compartment.
Make: How To Make Waterproof Mini Relays  In general there are two types of those PCB relays available, a 2 amp version and an 8 amp version. I'd recommend getting the 8 amp version if you're running an incandescent brake light bulb. (If you live in the US and don't want to do this then I will sell you one pre-made for $15 shipped.)
Step 4) Wire it all up. Since brake light strobe wiring varies from model to model, the wiring in the diagram below is simplified but all brake light strobes have two things in common: a 12V+ input for the brake light and a strobing 12V+ output.  The numbers on the diagram below correspond to the standard Bosch relay terminal designations if you decide to use one of those.
Re: Alternating Brake Light Strobe
« Reply #1 on: October 29, 2012, 03:24:27 PM »
Since none of my bikes have a BMU anymore so I can run LEDs I forgot about the fact that this would set off the BMU.  If you want to keep your BMU happy then what you could do is wire it as follows so that the brake light would go on normally and just the side lights would strobe.
See attached schematic.
