Author Topic: mystery fault....  (Read 10621 times)
jamie92j
mystery fault....
« on: October 20, 2012, 08:18:12 AM »
well my k100 just started a strange fault
its only got 36k on
splutters and coughs when throttle held around 2-3rpm
the really strange thing is the speedo gauge also rises up to around 20mph on idle (when at standstill!)
im thinking electrical, maybe regulator? as the coughing and spluttering is similar to a f650 when the reg/rec went on that
any thoughts?!
i need it fixed asap for work!!
Re: mystery fault....
« Reply #1 on: October 20, 2012, 10:19:40 AM »
Likely the throttle position switch is misadjusted, etc. Just unplug it for the moment. Its located at the aft side of the throttle bodies.
jamie92j
« Reply #2 on: October 20, 2012, 11:46:39 AM »
the throttle position switch has not been touched though, so surely its unlikely to move its self?
the bike was ok from cold, seemed to happen after 5-10 mins of riding once the bike was warm
which makes me think coils?
Iv checked the volts across the coils and that is fine (around 12v)
Iv also checked the resistance across the primary winding as per Haynes manual and there around 5k which also seems in spec although i don't have exact data for these
Trying to check across the secondary winding but the manual is not all that clear, im unsure of where the HT lead terminal is and where to measure from
any more thoughts?!
need the k100 experts help!!!
Bike is a 1989 k100lt, 36k on clock, UK model
« Reply #3 on: October 20, 2012, 12:26:51 PM »
... seemed to happen after 5-10 mins of riding once the bike was warm
How about the HES - hall effect sensor?
jamie92j
« Reply #4 on: October 20, 2012, 01:06:29 PM »
thought it could of been that
but the bike still idles fine once warm
it just wont rev up
« Reply #5 on: October 20, 2012, 01:16:39 PM »
it just wont rev up
You tried replacing the fuel filter, right?
jamie92j
« Reply #6 on: October 20, 2012, 01:19:15 PM »
doh  :embarass:
start with the basics....
jamie92j
« Reply #7 on: October 20, 2012, 04:39:27 PM »
been thinking about it and think its unlikely to be fuel filter (although i will check it)
Just been out to start it now after its rested for around 5 hours and its fine!
Problem only seems to start when it gets up to normal temp
« Reply #8 on: October 20, 2012, 05:10:32 PM »
sounds exactly like the hall sensors. easy and fairly cheap to fix with the honeywell sensors.
jamie92j
« Reply #9 on: October 20, 2012, 05:15:38 PM »
honeywell sensors?!
whats the kind of price i should be paying for a new HES?
« Reply #10 on: October 20, 2012, 05:32:40 PM »
There's a $50 used K75 Hall Effect Ignition Trigger listed at http://marketplace.ibmwr.org/ads/view/id/203891
Not sure if that'll fit your K100, or even if that's another name for a HES.
WoahGold
« Reply #11 on: October 20, 2012, 06:10:36 PM »
K75 hall effect sensor will not fit a K100. The sensors are aligned differently.
Duck has one though: http://www.kbikeparts.com/
« Reply #12 on: October 20, 2012, 06:15:12 PM »
The sensors itself is similar 75/100/1100, but the complete unit is different on a 75.
To test: remove the T-shaped cover, heat up the sensors with a hair dryer or similar (cold engine).
Start the bike, if it`s the HES that is the problem...it would now show up far earlier.
Inge K.
jamie92j
« Reply #13 on: October 20, 2012, 06:43:27 PM »
thanks for all the input people
will test the HES tomorrow morning with a cold engine
Also i am over in the UK so ordering parts from the states could be an issue, but thanks though
Will try 'Motobins' if it is the HES at fault
