Author Topic: Aftermarket heated grips with an OEM switch  (Read 42521 times)
Re: Aftermarket heated grips with an OEM switch
« Reply #25 on: January 14, 2018, 04:12:21 PM »
I miss drake.
Offline frodef
  • 1986 K75C
« Reply #26 on: March 20, 2021, 01:25:35 PM »
I'm looking to do this mod, with the wires through the handlebar. However I can't see any hole in the bar (between the clamps) to fish the wires out of. Is it safe to drill a hole? What diameter would you suggest?
Offline mw074
« Reply #27 on: March 20, 2021, 03:02:43 PM »
It is safe to drill a hole. Use whatever size that you have handy but allow for  the use of a rubber grommet.
  • Michigan
Offline frodef
  • 1986 K75C
« Reply #28 on: March 20, 2021, 03:17:57 PM »
Thanks. Drilled a hole 7-8mm and ran the wires. Don't have a grommet, guess I'll use some rubber or cloth tape and jam it in there.
