Author Topic: K75 sprag clutch and oil pressure sender  (Read 5135 times)
quis
« on: October 16, 2012, 11:31:31 AM »
Hey all. I've found this site super helpful for working on my 1990 K75S and hopefully might be able to help someone in the future here.
A few weeks ago my oil pressure light started coming on. Initially it was just when decelerating from high speed. The Haynes manual suggested that this was symptomatic of a failing oil pump. I gave the bike a look over and found a slight leak coming from the oil pressure sender. So I fitted a new one and problem sorted. The old one was in a pretty bad way, the pin was bent, no wonder it was failing. So, lesson one: if a light comes on it could well be down whatever sensor is responsible for that light.
Changing the oil pressure sender means doing an oil change (and might as well do the filter, even if it only had 2000 miles on it). I spent long time reading around for what oil was good. I eventually took the "these bikes are unstressed and will run on anything of the right grade" advice. So went to Halfords (in the UK, big chain auto parts store) and picked up a bottle of own-brand, semi-synthetic 15W-40. All seems to be fine after getting the bike running again. However, within a couple of days the bike developed the sprag clutch issue, where the starter spins but doesn't engage. Would only happen on a cold start, and not even every time, but still not desirable. I did some more reading around and got the idea that it could be down to the oil, especially since that was the last thing I'd done to the bike. So I went and shelled out for a bottle of Mobil 1 15W-50, fully synthetic "motorsports" oil. Whatever additives are in that stuff seem to have done the trick. It might just be suggestibility but the bike even feels like it runs smoother. So, lesson two: the kind of oil you put in your bike can make an immediate difference.
Offline ReneZ
Re: K75 sprag clutch and oil pressure sender
« Reply #1 on: November 04, 2012, 03:47:47 AM »
I would be very careful with that. The sprag clutch is known for not working properly when using motorbike oils, particularly full synthetics. What you have on an early K is a car engine, not a motorbike one. Motorbike oils have all kinds of additives for wet clutches (friction modifiers??) which might leave the sprag clutch too slippery to grip when you want to start. For this reason most advise to use a standard mineral oil. Further a change over from mineral to full synthetis could lead to leaking seals where you don't want. Read/search a bit more.
If the bike doesn't start to turn over, but the starter motor is running it normally means the sprag clutch is gummed up. There is not a lot of oil going there and a lot of short trips will faul it up. Only longer trips on a regular basis, warming the bike through and through will keep it clean (enough).
Greetings, Rene
BMW K100 - 1984
BMW K1200GT - 2003
Offline DRxBMW
« Reply #2 on: November 04, 2012, 09:14:02 PM »
WRONG, dyno oils are known for sprag issues !
Full synthetics kick ass, especially Mobil 1 15/50, truly an all season oil. FWIW, sticky sprags happen more in the earlier models for some unknown reason.
Rislone detergent treatment is the first avenue of attack.
http://www.ibmwr.org/ktech/sprag-clutch.shtml
Over 200K using Mobil 1 , NO seal leakage EVER !
Mega Miler Reno 890 K on a 75, uses Mobil 1 20/50 (MC specific)
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
