Author Topic: Front Brake Stuck On  (Read 5843 times)
WoahGold
« on: October 10, 2012, 03:31:11 PM »
For the short story skip down.
I was riding home this afternoon when I noticed that no matter how much throttle I gave the bike would not accelerate. Then when I'd pull in the clutch the bike would decelerate quickly. Then when I finally did get up to speed the bike had a VIOLENT shake in the front, at which point I decided to pull over. I parked in a Wells Fargo lot and noticed that it was quite difficult to walk the bike around it felt like they were stuck about half on. I pulled on the front lever and it moved almost without resistance. I hopped off and went to inspect the brakes and they were HOT. I was going to pull the brake lever off and check it but I had no flathead in the tool kit. I settled on working the lever repeatedly, letting the brakes cool and gave each of the calipers a couple of good love taps with the wrench at which point they released. I then rode home.
I'm not sure whether the stick was in the master cylinder or in the calipers but either way I dont want it to happen again and my gut says something needs some lubricant, but I'm not sure exactly what. I did recently change the brake lever, but I did grease it. Where should I look first?
Re: Front Brake Stuck On
« Reply #1 on: October 10, 2012, 04:03:05 PM »
Seems like MC piston haven`t returned fully, usually caused by corrosion and/or crystallized brake fluid
at outer end of the bore.
Inge K.
« Reply #2 on: October 10, 2012, 06:44:39 PM »
I'm with Inge...if they were both stuck it's the MC.
WoahGold
« Reply #3 on: October 10, 2012, 08:52:23 PM »
Makes sense to me, I'll open it up, clean it out, and hit it with some silicon spray. Thanks
Offline BobZ(IL)
« Reply #4 on: October 10, 2012, 09:42:24 PM »
If it's not the m/c, check for collapsed or blocked brake lines.
  • Bourbonnais IL
'93 K1100LT
'78 R100S
'05 R1200GS
Offline ReneZ
« Reply #5 on: November 04, 2012, 05:10:53 AM »
Make sure both holes in the bottom of the MC container are open. If you look into it you'll see what I mean. One is larger than the other.
Greetings, Rene
BMW K100 - 1984
BMW K1200GT - 2003
