Author Topic: Bulbs for dash pad switches?  (Read 3825 times)
Offline moynistan
  • Ignorance is bliss...
« on: October 05, 2012, 03:04:49 PM »
I am overhauling switches on my 4V K100 (91).  The 4 way flasher switch looks as though it has leads going to the empty socket under the hazard symbol.  Is there a bulb for this spot and if so what type, number, etc.?  Thanks in advance, and apologies if this is in the Lieberry, I searched with no luck.
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
Re: Bulbs for dash pad switches?
« Reply #1 on: October 05, 2012, 03:37:24 PM »
The early hazard switches did have three wires to them and a little bulb inside that the flasher relay blinked with the turn signals.  It was part of the switch and not a separate part.
If you're going to fiddle with installing a light in there then I'd go with an LED:
http://www.newark.com/lumex/ssl-lx3044id-12v/led-t-1-red-6mcd-635nm/dp/09J9513
Offline moynistan
« Reply #2 on: October 05, 2012, 09:49:44 PM »
 :hmm:
Maybe someday when I don't have 15 other loose ends...thanks
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
