Author Topic: Coolant temp sensor junkshow...  (Read 3295 times)
Offline moynistan
  • Ignorance is bliss...
« on: September 21, 2012, 04:52:50 PM »
OK, I replaced my coolant temp sensor today, and when I pulled it, I saw this:
Pulled it out with a pick and it looks like this:
Looks like a rubber band accidentally dropped into the system(?!), but if anyone knows better please sound off.  I haven't had any coolant leaks in the system that I know of...  Guess i should be glad it ended up someplace that I could remove it so easily?
Cheers,
KM
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
Re: Coolant temp sensor junkshow...
« Reply #1 on: September 21, 2012, 05:06:58 PM »
Its probably sealant from the water pump cover.
Offline moynistan
« Reply #2 on: September 21, 2012, 05:36:43 PM »
Yup, when I cleaned up the timing chain cover, I found the extruded sealant to be the same stuff.  good to get it out at any rate.
Kevin Moynihan
1958 R26
2001 R1150GS
1991 K100RS4V
