Lots make the mistake to think that the tighter they bolt it down the better it seals, particularly when they see/suspect a leak, but that's no use. The cover seals on the pressure exerted by the rubber bobbins around the bolts. If they are old/hart/damaged the cover will not seal properly. The bolts themselves are just about hand tight (bit more....)
