Author Topic: hesitation and no power???  (Read 5733 times)
Offline Fossil
  • '91 K100rs4V caretaker
« on: September 21, 2012, 07:51:40 AM »
I have just finished changing the rubber connectors under throttle bodys, (they were cracked). Everything is back in place as it should be and when I rode it I still had a stumble, poor throttle response, and low power and no rpm above 5K. What's next??
How can you be lost if you don't give a crap where you are?
lhead
Re: hesitation and no power???
« Reply #1 on: September 21, 2012, 07:59:35 AM »
Change out the fuel filter.
Offline Fossil
« Reply #2 on: September 21, 2012, 10:40:51 AM »
The filter was(?) new but I never did take tank off and totally empty it,just let the pump push out what was in there. I'll get the old filter out and try to get a look at the fuel pump sock. NAPA should have a match for it. Thanks for the tip.
Rick G
« Reply #3 on: September 21, 2012, 07:48:54 PM »
Make sure you have a good seal at the cylinder head junction. I have a friend here who had to try 3 or 4 times to get a seal and not for a lack of experience either.
« Reply #4 on: September 21, 2012, 08:03:31 PM »
I assume you replaced them with new ones, correct?
Easy to test for leaks.  Spray some starter fluid on them at idle to see if that increases the idle.
Offline Fossil
« Reply #5 on: September 21, 2012, 09:30:00 PM »
I replaced the orings as well as the rubber sleeves. The propane thing helped me get started on this hesitation problem. Thanks
« Reply #6 on: September 21, 2012, 09:38:45 PM »
Have you done this yet?
Renewing Heat Sink Compound on Ignition Module
It's one of the most overlooked maintenance tasks on the early 4Vs and causes the exact symptoms you describe.
Offline Fossil
« Reply #7 on: September 22, 2012, 12:30:30 PM »
I'm hoping that the fuel filter change and a very clean tank will solve the problem. I know about the ign module fix, but this hesitation comes on so quickly that the module can't heat up that fast,,,,,can it???
« Reply #8 on: September 22, 2012, 01:03:56 PM »
You want to replace the heat sink compound anyhow as regular maintenance and its a simple inexpensive task.  It certainly won't hurt.
