Author Topic: Went on holiday for three weeks and she wont start battery now flat from trying?  (Read 7006 times)
1986 k75s
Got back from hols wheeled the k75s out of the shed hit the starter button she started up then died . Probably a bit cold me thinks ,tried again huge backfire cloud of greyblue smoke then wouldnt start . Battery now gone flat so removed to charge on motorcycle charger. The plugs were soaked in fuel dried them and cleaned them but still didnt want to start . I notice the buzzing from the fuel pump had stopped the last few tries b4 i removed the battery , just the small backfire .
Was wondering if the fuel pump stops working when the battery gets really low on power ? Fuse hasnt blown that being fuse number 6 in fact no fuses have blown
Bike is a 1986 S model k75 an old dog in reality but with low mileage of 32000 for a 26 year old bike .
Advice please ?  :dunno
Since your fuel pump don`t turn anymore, measure if you got voltage at fuse #6 while pushing the starter button.
If you got power, the problem is the fuel pump, tank connector or related wiring.
If you ain`t got power, the problem is the FI relay or related wiring.
Inge K.
1986 k75s
Cheers friend i will try that can you explain the trick of reversing the pump to possibly unblock it  ?
Reverse the polarity at the pump.
Inge K.
1986 k75s
After a good charge on the battery i returned to the bike . I have learned a valuable lesson at this point BMWs are very fussy things for eg dont put the battery back in b4 you put the water filler in eg . A press of the starter and brooooommmm she starts up like nothing was wrong the fuel pump buzzing happily aswell .
So it would appear that a low battery is the cause of my problems and that is all .  :neener:
