Author Topic: Relocating ignition barrel switch, suggestions? removing the crash pad  (Read 9993 times)
Gubro30
I've seen some in the lower part of the air-box (Special Ks bikes), any other suggestions?
What about the heated grip switch?
Thanks!
Re: Relocating ignition barrel switch, suggestions? removing the crash pad
« Reply #1 on: August 31, 2012, 06:58:21 PM »
Possibly through the accessory outlet hole on the coil cover for a K75.
Or if you perform the headlamp modification as with the other Special-K's, then the ignition switch is in the headlamp bucket.
I dont have any really good ideas for the heated grip switch except to maybe use a micro-toggle SPDT switch in a discrete place and use it to switch a relay pair that activates the heated grips (one relay = low power; other relay = high power).
« Reply #2 on: August 31, 2012, 07:22:43 PM »
You could rewire a Euro headlight switch to turn the heated grips on and off.  It would just be an on/off switch but you really want to avoid using the low setting anyhow since it's been known to cause issues due to the resistive wire in the circuit heating up it's insulation, melting it off and causing a short.
Gubro30
« Reply #3 on: August 31, 2012, 07:42:50 PM »
Very interesting re the low setting, very useful info that popped up!
« Reply #4 on: August 31, 2012, 09:17:27 PM »
Here's what I did.
Now that my ABS is off, I have no other switches to worry about.
Gubro30
« Reply #5 on: September 03, 2012, 10:55:49 AM »
Here's an idea maybe? The ignition barrel should be roughly the same size as a cigarette lighter?
Offline argent brick
« Reply #6 on: September 03, 2012, 03:37:16 PM »
Would a slash 6 headlight bucket work?  They have the key switch built in on the left hand side.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Gubro30
« Reply #7 on: September 03, 2012, 08:50:08 PM »
@argent brick: Idea is good but I'm not (yet) going that route; I like the K100 std fairing I have now on it. I think I'll just have a mount machined for it!
« Reply #8 on: September 03, 2012, 09:38:19 PM »
I would be willing to bet money that the headlight buckets will interchange with a slight work around for the key switch.  Assuming of course that the
headlights are the same size.  The K100 std fairing does look decent though. Almost as good as a naked K75.
Lynn
1976 R60/6 RIP
