Author Topic: Tail Light/Parking Light Question - K1100RS  (Read 6915 times)
Offline BexarWolf
  • 1994 K1100RS - Rubik
« on: August 23, 2012, 12:05:37 AM »
I'm new to the K1100RS (mine is a '94) so I'm still learning......be gentle.  :embarass:
Should I be able to activate the brake light without the bike running?
Also, my parking light on the front appears to not be working. I've turned the ignition key to all the possible positions but I don't get a light. It'd be easy to assume it's burned out but wanted to throw this out before I start pulling bulbs.
Thanks in advance.
Sit tall in the saddle, hold your head up high. Keep your eyes fixed where the trail meets the sky. Live like you ain't afraid to die. Don't be scared. Just enjoy the ride. ~ Chris LeDoux
Offline Inge K.
Re: Tail Light/Parking Light Question - K1100RS
« Reply #1 on: August 23, 2012, 05:03:06 AM »
The brakelight can be activated when the ignition is on, you don`t need to have the engine running.
The front parklight is in the same circuit as the taillight.....so whenever the the taillight is on,
the front parklight should also be on.
Inge K.
  • Norway
« Reply #2 on: August 23, 2012, 08:28:52 AM »
FYI: The brake light doesn't work if the kill switch isn't straight up.
Offline BexarWolf
« Reply #3 on: August 23, 2012, 12:22:41 PM »
Thanks for the replies. I guess I had the kill switch in the other positions last night when I was fiddling with it and didn't realize it. I was looking at the tail light lens to see about mounting some LED brake lights I had left over from a Hyperlite install and wasn't having much success with the brake light.
I did get a bit of a surprise when I found the inside of the tail light lens slightly melted on the back of the lens. Everything is working and the bulb mounts look ok although I'll probably change them soon since the securing tabs on both of them are either brittle or broken.
« Reply #4 on: August 23, 2012, 01:37:51 PM »
Looks like somebody put too hot of a bulb in there.  It should only be a 10W bulb.
Offline Inge K.
« Reply #5 on: August 23, 2012, 05:27:56 PM »
Or the sidestand is down.
  • Norway
Offline BexarWolf
« Reply #6 on: August 23, 2012, 06:15:30 PM »
Ok, I think this might have been what happened. When I wheel it into the garage, I put the side stand down so I can get off. Then I put it up on the center stand. I probably still had the side stand down when I was checking the bulbs.
I'll see if it's a 10w bulb later tonight. I have another issue I have to deal with (i.e. removing melted plastic from a muffler Grrrrrrrr).
