[Sorry if this message is a duplicate. Something went wonky on the first post attempt]
After rebuilding the oil pump and generally poking around cleaning things, I finally got around to beginning the spline journey and made it through final drive removal. Duck, you're latest write-up on the process is awesome.
Splines in the FD look good and this end of the drive shaft seem decent.
2 items were encountered which I think officially qualify as problems to be addressed. Left side bearing race has a couple chips on the inner edge.
I suspect the chips may have been caused by 2 roller bearings from the assembly exiting their assigned seating without permission (@ about 12:00 and 2:30 in the picture).
Does rubberchickenracing make bushings for the FD pivot as well as the swing arm or maybe stock replacements are sufficient?
Also, could folks weigh in on the apparent wear on the left side pivot shaft?
Tomorrow night it's on to the swing arm and transmission extraction.
