fitting a Manuel fan switch to a pre 85 k100rs
Topic: fitting a Manuel fan switch to a pre 85 k100rs (Read 4148 times)
k100
August 17, 2012, 05:19:41 PM »
can sumone pleas explane how to fit fan switch to pree 85 k pleas. as to what typ of relay to ues our if it is safe to wire a switch in without using a relay in this model :hmm:
frankenduck
Adrninistrator
Re: fitting a Manuel fan switch to a pre 85 k100rs
Reply #1 on:
August 17, 2012, 06:26:20 PM »
I'd use a relay that's rated for at least 7.5 amps:
Pin 85: run through your switch to ground
Pin 86: switched power
Pin 30: tap into the rear side of fuse 7 (fan fuse)
Pin 87: power out to fan (yellow/violet wire
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
k100
Reply #2 on:
August 17, 2012, 09:40:22 PM »
thank you :2thumbup:
