Author Topic: Where Does This Ground Wire Connect  (Read 13293 times)
« on: August 12, 2012, 10:52:15 PM »
Putting the bike back together. Almost complete after three loooong days of nitrile gloves.
This electrical connector comes down from under the tank towards the battery / starter area and is grounded even though the jacket is red.
Where might I connect it?
Rick G
Re: Where Does This Ground Wire Connect
« Reply #1 on: August 13, 2012, 12:56:06 AM »
There is an earth connection on thr gearbox just above the coils.  Socket head screw 6mm thread and 5mm hex. There are usually more than one eth connected there.
« Reply #2 on: August 13, 2012, 03:15:18 PM »
Thanks, Rick!
I found this photo too (not my bike) that shows it connects to the same place as the battery ground.
Re: Where Does This SPRING Go?
« Reply #3 on: August 13, 2012, 04:25:54 PM »
This small spring is the only part left over from my clutch rebuild. I thought it came off the side stand / center stand, but for the life of me I can't see where.
« Reply #4 on: August 13, 2012, 05:25:44 PM »
Motorandy123
« Reply #5 on: August 13, 2012, 06:45:07 PM »
It looks like the rear brake pedal spring.
My bike has only one wire on that ground point, it is a smaller wire and goes
straight to the battery. Maybe 50 amp bikes have a bigger wire too?
« Reply #6 on: August 13, 2012, 08:01:19 PM »
When in doubt, check the fiche. #13?
Yeah - I did that.
I have two each of the #13's and the #7's and they're all considerably thicker and twice as long as this little leftover spring.
Offline Uffda
« Reply #7 on: August 13, 2012, 08:21:57 PM »
I had the same problem 2 years ago after doing my first spline job.  Same little spring left over with no obvious place to go.  And I posted the same question you had...."Where does this left over spring go?"  As Randy said, it's the brake lever spring.  One end goes between the #7 springs on your center stand and the other end attaches to a spot near your MC.  Good luck.
#9 in attachment
  • New England
  • 1995 K75RT
Robert
« Reply #8 on: August 13, 2012, 08:28:14 PM »
Bingo! That was it. Thanks, guys.
Offline Photog
« Reply #9 on: August 14, 2012, 08:23:32 AM »
Later K's (don't know what year, it's probably documented in here somewhere), have a bigger ground wire. Mine is an 87 and the factory wire is almost scary thin.
Euro Moto Electrics has a nice kit with upgraded battery wiring. You can roll your own too, of course. I found however, that the euromotoelectrics kit was very cost effective compared to a DIY effort.
  • NNE
  • K75-S
