Author Topic: Clutch Pack Balance Marks  (Read 6720 times)
« on: August 11, 2012, 05:11:35 PM »
So when I pulled the clutch pack it pretty much exploded onto the floor. Clumsy me. No chance of knowing its original balance configuration.
After cleaning, two parts have obvious markings, however the pressure plate has a marking on each side and I can't decide which is the one to use.
The more obvious pressure plate marking is white paint over a drilled indentation, while the mark on the other side is a faint yellow on the flexible band.
If I were to choose the painted white markings on each pressure piece, those marking would be almost 180 degrees apart when assembled.
If you have experience with these clutches please let me know the kind of marks you have seen and used.
Motorandy123
Re: Clutch Pack Balance Marks
« Reply #1 on: August 11, 2012, 05:28:41 PM »
Sorry no help but Motobins is selling a complete clutch for $65 see here (under special offers);
 http://www.motobins.co.uk/bmw-parts.php?model=K%20Series
I wonder if it comes prebalanced? Or with marks?
Offline Duc750
« Reply #2 on: August 11, 2012, 08:18:16 PM »
That won't be pre balanced, when I put mine back together I put all the drillings at 120 degrees from each other (or as close as I could get it) seems to have worked so far!
2001 K1100LTIC not even run it at 52K
1994 Duc 907ie
1998 R850R
1987 Duc 750 Paso
Offline pallum
« Reply #3 on: August 12, 2012, 12:31:36 AM »
I put mine back together without matching any markings to see if it would do anything (hey, somebody's gotta try it...). No problems so far *knock on wood*
In any case, line up the white markers together and put them 120 degrees either way from the yellow marker on the clutch housing if you want to stick with the Clymer.
  • Federal Way, WA
« Reply #4 on: August 12, 2012, 02:14:13 AM »
Thanks for all the suggestions.
I decided to space out the three obvious markings which ended up putting them at about 12 o'clock, 4 o'clock, and 9 o'clock.
I hope to rev it up on Sunday.
Rick G
« Reply #5 on: August 12, 2012, 02:26:10 AM »
Before you put it back make sure the pressure and drive plate are now warped.  They sometimes get a dish in them and then only grab at the outside edge of the plate.
Put a straight edge across and check for a dish.
If there is a dish then you need a new plate because it just isn't worth machining them.
