Author Topic: Best Brake Hose Solution  (Read 7678 times)
« on: August 10, 2012, 01:13:04 AM »
What's the smartest way to upgrade the oooold brake hoses on my ABS K75?
Replacement hoses from the dealer? Online retailer?
Re: Best Brake Hose Solution
« Reply #1 on: August 10, 2012, 01:29:53 AM »
I have some from Speigler. Great service from them. Got a few on clearance from a K75 T (C bars), and ordered a rear set and one for the high bars (they called me, and had me check the length, to make sure I ordered the right ones) directly from them.
Motorandy123
« Reply #2 on: August 10, 2012, 05:37:52 PM »
« Reply #3 on: August 10, 2012, 05:48:51 PM »
+1 on Speiglers.
I have them on the '95.
You should have said you thinking about them, you could have looked them over at the cabin.
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
Offline GasStation
  • 93 K75S Mystic Red
« Reply #4 on: August 11, 2012, 01:15:57 AM »
I also replaced my 20-year old OEM brake lines on spec with Speigler. Those are C-bars with barbacks, so the boys at Speigler custom made a line for my bike at no extra cost. I measured what I wanted using a piece of nylon cord.
93 K75S Mystic Red
IBA #9469
« Reply #5 on: August 11, 2012, 11:12:45 AM »
Any local shop can build a set of brake hoses. Just pull yours and take them in with you.
« Reply #6 on: August 12, 2012, 02:16:56 AM »
All good advice. Thanks.
Replacing break lines is my next move assuming I recover gracefully from the rear main seal / all-spline lube job I'm wrapping up now.
« Reply #7 on: August 12, 2012, 01:02:30 PM »
Any?  There's a bunch in Seattle that won't.
« Reply #8 on: August 12, 2012, 01:56:32 PM »
F off. I guess I haven't coooled off yet. :neener:
OK, call around and find a local shop to do it. Seattle has to have one.
Offline CubPilot
« Reply #9 on: August 12, 2012, 05:14:45 PM »
I took mine to a Hydraulic shop that has the machines for doing the crimps.   5 hoses, all braided stainless, banjo fittings oriented in the right direction, and a hand full of seal rings.  They must have thought I was a real klutz, I had enough seal rings to do three bikes.    All in all $123.65.   I drop them off on my way to work in the morning and picked them up on my way home that afternoon.  I thought it was a good deal.
