Author Topic: K75 smoking (oil) after 5minutes on side-stand?  (Read 10624 times)
Gubro30
« on: August 06, 2012, 08:17:37 PM »
Literally no more than 5minutes, and it burns oil. Starts up clean and smoke free after forever on center stand though.
Valve guide oil seals maybe?
Re: K75 smoking (oil) after 5minutes on side-stand?
« Reply #1 on: August 06, 2012, 08:30:15 PM »
Nothing to worry about.  Early K bikes' piston rings let some oil seep into the combustion chamber.  BMW changed the rings in June of 88.
How to minimize it:
1) Use the center stand.
2) Turn the bike off and tilt it to the right for about 10 seconds to let the oil drain back into the sump.
Gubro30
« Reply #2 on: August 07, 2012, 10:30:56 AM »
Thanks Duck.
I would've believed that leaving it on side stand overnight would make it smoke, but not such a short time!
Offline dfx
« Reply #3 on: December 13, 2014, 02:40:50 PM »
Thanks Duck.
Hi, I hope I can just pick up where this thread left off more than 2 years ago. I also get the smoke problem that seems to be connected with the way the bike is parked. When the motor is hot, I can leave the bike on the sidestand for 5 minutes and then it smokes like hell on restarting. Trouble is, parking it on the centre stand can be painful. As for tilting it the other way, I'd never get it back up again! What I don't understand is, I've never had to add any oil. Although, when I bought the bike a year ago, I immediately changed the oil with fully synthetic stuff and it was only after that I noticed the problem.
  • Alsace, France
  • K100RT 1986
Offline ljjohns
« Reply #4 on: December 13, 2014, 05:50:13 PM »
FWIW: have you ever probed a big hole in a tooth or gum and then have the dentist tell you that it was miniscule?
That's how I view smoking from a rest position on the sidestand: it's a miniscule dribble of oil into the cylinders that is being burned off in the first few minutes of operation upon starting. It seems like a big thing, but it's really almost infinitesimal.
Think of riding under those conditions as doing your small part to reduce the mosquito population....
Larry Johnson
El Paso TX
1 K75, 3 K11's, 1K12, all of which sit for a long time on their side stands (cuz I'm old and infirm)  :musicboohoo:
  • All in El Paso, garaged in my house, my wife's house, and friends' houses
  • 91K75RT, 95K1100LT, 96K1100LT (restoration project) 2003 K1200LT
Larry Johnson
El Paso TX
« Reply #5 on: December 13, 2014, 07:16:06 PM »
They all do that :hehehe
swissmann
« Reply #6 on: December 14, 2014, 08:29:42 AM »
hello i have just joined and looking to replace my bike for a nice k75/100rt  and cannot find a answer to what should be a easy question  what engine oil is the best some say dry clutch use castrol gtx others say after 20000 miles use fully synthetic oil? i am at a loss and when i get one asap i would like to give it a oil change/service. also any members in county durham   uk  to show me any pointers
many thanks
happy christmas
peter
« Reply #7 on: December 14, 2014, 10:07:10 AM »
greetings swissmann...
my motobricks getts front to back...
forks = honda ss8-10...
brakes = any dot 4...
radiator = prestone 50/50...
fueltank = any no corn ethly...
engine = mobil 1 syn 20-50...
gearbox = mobil 1 syn 75-140
finaldrive = mobil 1 syn 75-90...
more here...
Offline dfx
« Reply #8 on: December 14, 2014, 10:12:41 AM »
Mine is around 5w-40w I think, maybe that was the problem a thicker oil might not get into the combustion chamber as easily. But is 20-50 thin enough for sub zero cold starts?
  • Alsace, France
  • K100RT 1986
« Reply #9 on: December 14, 2014, 10:15:05 AM »
rode last weekend... it was 17deg usa... one push start... purred like a tight pussy...
if its below 0 usa... im not motobricking... im ice fishing...
