Author Topic: 135 db horns  (Read 5542 times)
jeffhestand
135 db horns
« on: August 06, 2012, 11:41:35 AM »
i was wanting to replace my anemic horns on my 85 K100 with some blasters... Can i just direct replace them or do i have to have special wiring etc....??? Thanks
Re: 135 db horns
« Reply #1 on: August 06, 2012, 05:25:43 PM »
K bikes already have horn relays, so you should be good. I'd bump the horn and cooling fan fuse up to 30 amps, though. I had to hit the horn (stebel nautilus, modified for a remote pump) while running hard (95mph) in 100 degree weather. Cooling fan must have been on, so it honked, and then stopped, and I started getting the coolant light when I would wind up to pass.
jeffhestand
Re: 135 db horns
« Reply #2 on: August 08, 2012, 03:54:54 PM »
which fuse is the one in question and thanks
Re: 135 db horns
« Reply #3 on: August 08, 2012, 04:08:37 PM »
#7
