Author Topic: Oil pressure light not working - K1100  (Read 3482 times)
Offline lhead
« on: August 05, 2012, 09:28:57 AM »
New to K bikes. I'm assuming the light is supposed to illuminate with key on, go out after starting (assuming adequate OP that is). I know I have pressure because I started the bike after an oil/filter change yesterday and could hear the difference in the engine when pressure built up.
Most likely a burnt out bulb in the instrument cluster or a bad sending unit?
Thanks,
Charlie
1993 K1100rs
Re: Oil pressure light not working - K1100
« Reply #1 on: August 05, 2012, 09:39:39 AM »
Ground the connector at the sensor, if your light shows up...you need a new sensor.
Inge K.
