Author Topic: K100rs4v  (Read 4031 times)
Offline Fossil
  • '91 K100rs4V caretaker
K100rs4v
« on: August 04, 2012, 05:46:07 PM »
Just came back from short ride after some amateur repair work. It went pretty well but it has some flat spots in the rpm range. If I baby the throttle it will accelerate nicely and the next time it won't. I don't hear the 'click' at the tps but hesitate to screw with it. Could that be it?
How can you be lost if you don't give a crap where you are?
Rick G
Re: K100rs4v
« Reply #1 on: August 04, 2012, 08:11:50 PM »
I doubt it would be caused by the TPS but sounds like a leak in the inlet tract. Check in the Lieberry I am sure Duck has a thread about testing for inlet leaks using a propane torch.  Unlit of course.
Re: K100rs4v
« Reply #2 on: August 05, 2012, 06:16:17 AM »
You won`t hear a click on a Motronic euqipped bike like yours, as two pot. meters is used in the TPS.
Jetronic euqipped bikes (2V) have two switches in the TPS, on these ones you should hear a click.
Inge K.
Re: K100rs4v
« Reply #3 on: August 05, 2012, 09:33:44 AM »
