Author Topic: Handlebar pad switches  (Read 6594 times)
Offline 2slow
« on: August 03, 2012, 04:31:45 PM »
Has anybody found aftermarket switches that will fit into the stock cut out's on the handlebar pads it's for an 85 k100  thanks
I dedicate this beer to "Pittsburgh Nellie"; a Welsh Lady of the night who could do things with her one good arm that'd make you forget that *thing* on her neck
Offline Opus
  • 1988 K100 LT
Re: Handlebar pad switches
« Reply #1 on: August 03, 2012, 06:13:46 PM »
You can use a lighted switch but you may have to shim it in place with some foam tape.
I was looking at that for my running lights. So far I have not found them with out going through a dealer.
Toney
Offline argent brick
« Reply #2 on: August 03, 2012, 11:22:20 PM »
Mount the switch into the stock cut cover. That way you do not have to use any foam tape; and it is easy to make it "stock" again.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
« Reply #3 on: August 04, 2012, 01:49:22 PM »
If I understood what you said, basically buy a narrow enough switch and cut the "stock blank filler" to fit the narrow switch in it.
I did this for my running lights and fan switch's on both of my LT's.
Plenty of blank switch positions on them.
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
« Reply #4 on: August 05, 2012, 03:02:13 AM »
You understood just fine. Personally, I would consider a push button switch over a rocker style.
Lynn
1976 R60/6 RIP
