Author Topic: k100 rs will no do mour than 105 mph  (Read 14399 times)
Offline k100
« on: August 02, 2012, 08:47:35 AM »
right my brick seams to do everything it should and do it well exept it refuses to go moure than 105mph it gets there no fus but then will not go aney faster aney geses as to whats going on  :dunno
Rick G
Re: k100 rs will no do mour than 105 mph
« Reply #1 on: August 02, 2012, 08:52:34 AM »
Will it rev past 6500rpm
Offline k100
« Reply #2 on: August 02, 2012, 08:56:26 AM »
yes it redlins in the lower gears just in top the best i have bean abell to get out of it is 170 kph
Rick G
« Reply #3 on: August 02, 2012, 07:40:43 PM »
I asked that because some of the bikes that were made for the swiss market were limited to 6500rpm to limit horsepower and they found their way to many corners of the globe.
Check to see if you are getting full throttle. You can see the throttle as it is opening on the left side just in front of the coils, turn the grip to flat out and see if you can push the linkage any futher than where it stops.
Offline k100
« Reply #4 on: August 02, 2012, 07:58:39 PM »
 :k100rs yes the throttle seams to function as it should and it will redline in the lower gears doesn't seam to be down on power at all just wont clime past 105 mph about
Offline k100
« Reply #5 on: August 03, 2012, 05:48:45 AM »
 :krsb dont get me roung i have bean riding big road bikes sins 1978 and got my ferst k100 12munths ago best all round motourcycle in the world as far as im concernd just wont it to perform the way it should so aney sugestions as to why this state of afears should exeisty would be mour than apresiated and thanks for the advice so far gyes
Rick G
« Reply #6 on: August 03, 2012, 07:35:19 AM »
Does it run out past the 170kph mark in 4th gear I am just wondering if someone has had a play with and maybe put a speed limiter on it.
Offline Duc750
« Reply #7 on: August 03, 2012, 08:41:43 AM »
That sounds like a japanese market restriction, were these ever sold in japan?
2001 K1100LTIC not even run it at 52K
1994 Duc 907ie
1998 R850R
1987 Duc 750 Paso
Rick G
« Reply #8 on: August 03, 2012, 08:44:48 AM »
There were a lot sold to Japan and they are turning up in Oz but not with any restriction like that they have a red light if you go over 80kph.
Offline k100
« Reply #9 on: August 03, 2012, 08:52:02 AM »
no just wont do it
Offline k100
« Reply #10 on: August 03, 2012, 08:54:48 AM »
what should redline be in 4 how fast thinking maby its geard down .
Rick G
« Reply #11 on: August 03, 2012, 09:02:42 AM »
In 4th you should be able to go to at least 180.
Offline k100
« Reply #12 on: August 03, 2012, 09:27:19 AM »
wont pull 160 redlining in 4 must be geard down
so were would i start
Offline k100
« Reply #13 on: August 03, 2012, 09:38:03 AM »
mind you it flys to the ton didnt think you could play with the gearing on the like that but must be abel to
Offline k100
« Reply #14 on: August 03, 2012, 06:48:12 PM »
Definatly gering is doing 8500 rpm at 155 kph in 4 gear so where dus such low gearing come from
Offline k100
« Reply #15 on: August 17, 2012, 05:35:14 PM »
its the speedo that wont go over 100 not the bike aded a gps to see and the bike go as expected speedo just reads way slow at hy speed anybody know why this my be ? ps its pree 85 seams to make a difference everywhere else
Offline Fifth Horseman
« Reply #16 on: August 17, 2012, 05:48:39 PM »
Try cleaning the speedo sensor thats fitted on the final drive (remove to clean).  It's probably either that or the speedo itself is faulty.
'99 K1100
Offline k100
« Reply #17 on: August 17, 2012, 09:37:49 PM »
ok will give that a try let yous know how it goes
Offline k100
« Reply #18 on: August 18, 2012, 05:00:52 AM »
clean the sensor bike now indicats 10k les than actuwell speed ie it tells me im doing 100 when its doing  110 indicated 80 atuwell 90 so the error is a consistant 10 k idears ?  :dunno2: will strip it downb whem i get time for now i just youse the taco for speed 4000 =100k
Offline Howard64180
  • 1989 K100
« Reply #19 on: August 18, 2012, 02:11:25 PM »
Hi, I'm a newbie poster on here but have gained loads of invaluable info as a lurker over the last month or so.  My 1994 K1100rs speedometer was reading way too fast but I was able to reset it using the info on this thread: http://www.motobrick.com/index.php?topic=599.0 - and a GPS to check my settings.
