Author Topic: Rocket Fuel -110 ?  (Read 3856 times)
Offline sh00ter
Rocket Fuel -110 ?
« on: July 29, 2012, 01:56:28 PM »
Anyone ever seen this at the local pumping station?  Is there such a thing as too much octane??
'94 1100 RS
Offline racinrich
Re: Rocket Fuel -110 ?
« Reply #1 on: July 29, 2012, 06:26:04 PM »
yes and yes.higher octane burns slower to prevent detonation.if its still burning when exhaust valve opens flame travels over valve burning  and finish in pipes by O2 sensor.bad for valves.burn should be done when valve opens.cam,advance and injection are all tailored for a specific fuel range.unburned air and fuel screw with O2 sensor and cause system to try and correct ,system may not be able to keep it in parameters usually causing other driveability issues.
When I have done this I use math to blend not, 100 %.IE 1gal 93 + 1 gal 110. 93+110=203 divided by 2 gal =101.5.
good luck
1993 k1100 lt silk blue
des plaines ill
USA
Rick G
« Reply #2 on: July 29, 2012, 07:52:28 PM »
You will waste your money to no advantage.
