Author Topic: Rear brake lights LED bulb options/sizes/type?  (Read 8968 times)
Gubro30
« on: July 26, 2012, 10:31:17 PM »
Basically, what do I order on ebay? Will I almost certainly have a bulb-out warning light with a LED bulb?
Thanks!
Offline Opus
  • 1988 K100 LT
Re: Rear brake lights LED bulb options/sizes/type?
« Reply #2 on: July 27, 2012, 09:45:41 AM »
Or you can get the KIT from the link in Frankenduck's post. I think it has everthing you would need to go LED. :hmm:
Toney
Gubro30
« Reply #3 on: July 27, 2012, 04:56:55 PM »
Thanks!
Duck: will I get a bulb out warning with that led bulb you suggested on ebay? How do I know if it's polarized?
« Reply #4 on: July 27, 2012, 06:01:06 PM »
Thanks!
I don't know.  I always get rid of the BMU as described in the motobrick link I posted above.  The BMU expects a 21W filament to test so my guess would be that it will light up the BMU indicator in the cluster if you install an LED unless the LED has been specifically designed to emulate a 21W filament bnulb..
Try running current through it both ways.
Motorandy123
« Reply #5 on: July 28, 2012, 04:14:38 PM »
Um the EBAY link was for a 1156 single post bulb. Doesn't the brake light need 1157 dual post?
« Reply #6 on: July 28, 2012, 04:53:43 PM »
You might check to see if there is room to just ADD a socket and bulb to the OEM.
Offline blakey
  • Learn to listen, listen to learn.
« Reply #7 on: July 28, 2012, 08:47:45 PM »
Tail light bulb is single post. Same as the stop light bulb.
blakey
K100RS 1986 RED!
North of Bris Vegas, Queensland, Oz.
« Reply #8 on: July 29, 2012, 07:52:41 PM »
The tail light is shorter/smaller diameter than an 1156.
Offline blakey
« Reply #9 on: July 29, 2012, 08:17:45 PM »
Thanks for clarifying that frankenduck.
"Same as the stop light bulb" meant single post, not bulb size.
blakey
K100RS 1986 RED!
« Reply #10 on: July 30, 2012, 06:56:54 PM »
Yup, both have a 15mm diameter base.
Offline Conrad325i
« Reply #11 on: March 11, 2016, 04:44:30 PM »
What is the stock tail light size? Not brake, but running light.
  • 1986 K75C
-Isaac
The Hills and Valleys of East Tennessee
