Author Topic: To Paint or Not to Paint, The Muffler that is...  (Read 10842 times)
Offline Opus
  • 1988 K100 LT
« on: July 19, 2012, 10:33:06 AM »
Okay gang.
Here is the question. If your muffler had battery acid spilt on it and the chrome was turning 4 diffrent colors from heat.
Would you paint it or try some other way to repair/replace it?
I have some flat black grill paint that is good up to 1200 deg F. that I have used before on my gas grills and it worked great and came out looking good.
I was thinking that I could tape off the tip ( still looks good ) and paint the rest up to the header pipes flat black.
I'm not a big Chrome person so covering it would not be an issue.
Well ball been tossed up! Who is going to kick it 1st?
Opus!
Toney
Offline motodude
Re: To Paint or Not to Paint, The Muffler that is...
« Reply #1 on: July 19, 2012, 10:38:05 AM »
You would probably want to attempt to neutralize the acid somehow.  Or, I would suspect it would continue to dissolve your muffler from under the paint.  Maybe?... :dunno
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
Offline Opus
  • 1988 K100 LT
« Reply #3 on: July 19, 2012, 10:50:40 AM »
@ Tom
Acid took care of. It was that way when I got it. I washed it off really good when I got it to make sure.
Looks like the battery froze and busted. They had cleaned it up but not before it had got to the muffler.
If I do it I will have to remove it and do a good cleaning and light sanding anyway.
@ Frankenduck
That looks cool! That may be an option also.
Toney
Offline Opus
  • 1988 K100 LT
« Reply #4 on: July 19, 2012, 03:02:36 PM »
Here is a few pic to see what I have to work with.
Looks like it had a shield on it at one time. They may have cut off the mounting brackets.
The black patch in #502 is where I tested the paint. I ran the bike until hot then let it cool, then did it a again.
Paint seems to stick and does not rub off.
Fun, Fun...
Toney
« Reply #5 on: July 19, 2012, 03:15:20 PM »
A lot of times the mounting brackets for the heat shield rust off.
Offline motodude
« Reply #6 on: July 19, 2012, 05:51:37 PM »
@ Tom
@ Frankenduck
+1 on Frank's ceramic coating.  That's definitely on my todo list for my new K75.
Tom
'95 K75RT
'90 K75RT
« Reply #7 on: July 19, 2012, 06:15:36 PM »
Offline Opus
  • 1988 K100 LT
« Reply #8 on: July 19, 2012, 06:54:41 PM »
Okay Frankenduck!
Sold.
Will start working on it Friday.
(Showoff  :tongue) LOL
Will post pic when done.
Toney
Offline Opus
  • 1988 K100 LT
« Reply #9 on: July 23, 2012, 07:28:06 PM »
Okay Gang,
Here is the update.
What do you think?
Toney
« Reply #10 on: July 28, 2012, 05:02:23 PM »
Very nice Opus!
